Frank_Borrmann
Jun 03, 2017Follower
GS105Ev2 firmwareupdate fails
Hi, updated from 1.x till 1.4.0.9 worked well. I'm very cautious so i didn't make large steps, only one after another. But the last one fpr 1.5.0.4 does not work. I strictly followed this up...
- Apr 10, 2018
Hi,
Just bought the GS105Ev2 and ended up here after looking how to update firmware and bootloader too as it seems to be tricky.
I ended up finding that the latest firmware package available on Netgear website (1.5.0.5) doesn't contain bootloader update nor allows to update it. But firmware package 1.5.0.4 does !
So to simply update firmware and bootloader to the latest versions:
- Update firmware with 1.5.0.4 with ProSafe Plus / reboot
- Connect to GS105Ev2 web gui, it will ask to update booloader, provide the bootloader update requested and contained in the package, it's GS105PE_loader_V1.4.0.5-VB.bin in my case / reboot
- Update firmware with 1.5.0.5 with ProSafe Plus or web gui / reboot
Et voilà
XavierLL
Jun 04, 2017NETGEAR Employee Retired
HI Frank_Borman
Welcome to our community!
Seems as an issue in the browser that blocks the redirect to the loader page, could you try on step 9 to :
Type http://x.x.x.x/loader_upg.htm (x.x.x.x represents your GS105E’s IP address)
And see upload the bootloader so the firmware upgrade is complete.
Hope it helps!
Xavier Lleixa
NETGEAR CBU PLM
pchood
Sep 18, 2017Guide
Should this work on the GS105PE? I upgraded the frimware on 2 of mine but I didn't get the bootloader options and its running the old bootloader? They seem to be working, what issues does the wrong bootloader verision cause?
- pchoodSep 18, 2017Guide
I should have been more clear on my last post, I did try the /loader_upg.htm but it does not load a web page.
- vdmcobusOct 25, 2017Aspirant
Hi,
I am also experiencing problems with the FW upgrade. On mine the bootloader page came up, but it gave me and error when it tried to download the bootloader FW. I tried it a couple of times. I then decide to downgrade it to the previous version, and I now have a brick. I have tried TFTP to connect to it but without any luck.
- pchoodOct 25, 2017Guide
I was never able to update the boot-loader. But so far they are still running. Hoping if the power ever flashes they will turn back on ok. Let me know if Netgear ever has any advice for this situation.
