jrmckins
May 04, 2020Guide
GS105Ev2 not getting IP Address from DHCP
I have a GS105Ev2 that I plugged into my network today. All I have plugged into that is the cable to another switch and my laptop. My laptop gets an IP address from DHCP (192.168.87.43) just fine but...
- May 04, 2020
Here's what I had to do once I figured out the issue was some jacked up firmware:
1. Install ProSAFE Plus Configuration Utility on a windows system
2. manually configure the laptop to use 192.168.0.210; netmask of 255.255.255.0
3. Download the latest firmware from: https://www.netgear.com/support/product/GS105Ev2.aspx#download
4. Apply the firmware using ProSAFE Plus Configuration Utility
5. Factory reset the switch
I was then able to browse to the switch and use the default password (password) to get in.
Thanks to everyone that helped.
jrmckins
May 04, 2020Guide
"You can't reach the 192.168.0.239/24 IP address because your LAN subnet is configured to 192.168.87.0/24 - two different IPv4 subnetworks."
Yes, I even stated I didn't expect that to work.
That's also the problem, why is it 192.168.0.239 and not getting an address from DHCP???
"Double check the subnet is set to 192.168.0.0/24 (255.255.255.0)"
I did.
I also tried multiple cables/ports. It's not working with DHCP.
schumaku
May 04, 2020Guru - Experienced User
One more idea (silly me checked the GS108Ev2 before): Does the discovery tool show a switch firmware version version number before 1.3.0.1? Reson asking is because of very early firmware (1.2.x.x) does not come with a Web GUI, and it was mainly an early factory firmware. In this case (I hope you have a Windows system at hand!), you need to go the hard way and use the ProSAFE Plus Configuration Utility _before_ the curent 2.7.2, e.g. https://kb.netgear.com/000051197/ProSAFE-Plus-Configuration-Utility-v2-5-3 for backward compatibility.
- jrmckinsMay 04, 2020Guide
It shows V5.4.0.3 ... That doesn't seem to be a valid firmware.
- schumakuMay 04, 2020Guru - Experienced User
Ok, this is is it: You got a switch with a specific customer/project specific firmware. Updating with the utility however to the current one should be possible. Look here FMI: GS105Ev2 FW reads v5.4.0.3
Yeah, as soon as I checked I figured that was the issue. Time to blow the dust of a windows system so I can run that tool.
Thanks
Oh FFS, my windows laptop doesn't have an ethernet port.
