jrmckins
May 04, 2020Guide
GS105Ev2 not getting IP Address from DHCP
I have a GS105Ev2 that I plugged into my network today. All I have plugged into that is the cable to another switch and my laptop. My laptop gets an IP address from DHCP (192.168.87.43) just fine but...
- May 04, 2020
Here's what I had to do once I figured out the issue was some jacked up firmware:
1. Install ProSAFE Plus Configuration Utility on a windows system
2. manually configure the laptop to use 192.168.0.210; netmask of 255.255.255.0
3. Download the latest firmware from: https://www.netgear.com/support/product/GS105Ev2.aspx#download
4. Apply the firmware using ProSAFE Plus Configuration Utility
5. Factory reset the switch
I was then able to browse to the switch and use the default password (password) to get in.
Thanks to everyone that helped.
schumaku
May 04, 2020Guru - Experienced User
Ok, this is is it: You got a switch with a specific customer/project specific firmware. Updating with the utility however to the current one should be possible. Look here FMI: GS105Ev2 FW reads v5.4.0.3
jrmckins
May 04, 2020Guide
Yeah, as soon as I checked I figured that was the issue. Time to blow the dust of a windows system so I can run that tool.
Thanks
Oh FFS, my windows laptop doesn't have an ethernet port.
