jrmckins
May 04, 2020Guide
GS105Ev2 not getting IP Address from DHCP
I have a GS105Ev2 that I plugged into my network today. All I have plugged into that is the cable to another switch and my laptop. My laptop gets an IP address from DHCP (192.168.87.43) just fine but...
- May 04, 2020
Here's what I had to do once I figured out the issue was some jacked up firmware:
1. Install ProSAFE Plus Configuration Utility on a windows system
2. manually configure the laptop to use 192.168.0.210; netmask of 255.255.255.0
3. Download the latest firmware from: https://www.netgear.com/support/product/GS105Ev2.aspx#download
4. Apply the firmware using ProSAFE Plus Configuration Utility
5. Factory reset the switch
I was then able to browse to the switch and use the default password (password) to get in.
Thanks to everyone that helped.
schumaku
May 04, 2020Guru - Experienced User
One more idea (silly me checked the GS108Ev2 before): Does the discovery tool show a switch firmware version version number before 1.3.0.1? Reson asking is because of very early firmware (1.2.x.x) does not come with a Web GUI, and it was mainly an early factory firmware. In this case (I hope you have a Windows system at hand!), you need to go the hard way and use the ProSAFE Plus Configuration Utility _before_ the curent 2.7.2, e.g. https://kb.netgear.com/000051197/ProSAFE-Plus-Configuration-Utility-v2-5-3 for backward compatibility.
jrmckins
May 04, 2020Guide
