israelg
Jan 08, 2017Follower
GS105Ev2 password change crashes in win10 and doesnt change
Cannot change the default, no factory changes have ben made except IP address, have tried even simple passwords, always crashes the config app. Any suggestions would be appreciated. Using utility 2.3...
- Retired_MemberJan 10, 2017
Hi israelg,
Very appreciate the information that you provided, engineer did see the application crash, please uninstall Plus Utility v2.3.25, and re-install your previous version of Plus Utility (v2.3.24). We will have a fixing release soon.
Retired_Member
Jan 09, 2017Hi israelg,
Welcome to NETGEAR community! To default switch from Utility, are you following below steps?
1> Launch Utility v2.3.25 and select the switch
2> Click "Apply" button and enter right password
3> Select "System->Maintenance->Factory Default", enable checkbox and click "Apply"
4> After that, switch will return to its factory settings
If yes, can you tell us which GS105Ev2 firmware version loading?
"Crash the config app" meaning Utiltiy crash after click "Apply" button? If no, very appreciate if you could clarify more in detail.
