Mike_O_90025's avatar
Mike_O_90025
GS105PE Not allowing firmware upgrade
When I try to put the switch into bootloader mode to upgrade the firmware, the switch stops responding to pings, and refuses to allow me to do anything with it until I reboot it. Traffic continues to...
  • schumaku's avatar
    schumaku
    Sep 15, 2023
    From my old notes - many months passed since updating bunches of GS105PE-  I've seen the switch rebooting and entering into the loader mode. In this state, a Web form is called, allowing to upload the new firmware image.
    Worth a try is to update the switch in the off-network mode, without a DHCP server on the LAN, just connected to a PC adapter, configuring the PC to e.g. to a static IP address of 192.168.0.123 and 255.255.255.0 as the subnet mask, and then access the GS105PE on http://192.168.0.239/
    Note: If you are unsure how to do this, it's all in the RT*M, Gigabit Ethernet Plus Switches User Manual, in the "Access a switch that is off-network" P.19 ff.
    Here I'm at my wits end on this...
ProSupport for Business
