jammac
Mar 06, 2017Follower
GS105PE half-duplex
Can this switch do 10 and 100 Mbps in full AND half-duplex?
Would be too easy if this info was given in the specs ;-)
Thanks.
- JohnRoNETGEAR Employee Retired
Hi jammac,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
- Feb 22, 2022Retired_Member
