Xavier007
Jun 11, 2022Follower
GS108E Guest Network VLAN
Hello NETGEAR Com!! I would like to isolate my Guest Network (currently residing on the NETGEAR CAX30 WiFi Router/Modem combo) on the NETGEAR GS108E Swicth. I'm currently using the Guest Network...
schumaku
Jun 12, 2022Guru - Experienced User
Here again, like on all common consumer Netgear routers: What is advertised as a guest network in the marketing blush, becomes a little bit more clear when looking e.g. into the Nighthawk AX6 AX2700 WiFI Cable Modem Router User Manual does designate it like
"Set up a guest WiFi network
A guest network allows visitors to use the Internet without using your WiFi security
password or with a different WiFi password. By default, the guest WiFi network is
disabled. You can enable and configure the guest WiFi network for each WiFi band."
The point is "guest WiFi network" - to my knowledge, all these devices don't have a real wired isolated guest network, neither on a dedicated port, nor on a VLAN.
So there is nothing these web configured or smart or managed switches can do in this context, at least not without adding e.g. an additional router.
-Kurt
