burchbri
Apr 18, 2018Aspirant
GS108Ev3 firmware upgrade failed and cannot factory reset
I have three of these switches, which have been running with firmware 2.00.08 firmware for 2 years. I upgraded each of them with the web gui under linux from the older as-shipped firmware. Recently, ...
- May 02, 2018
Thanks, Dane. I will resist the temptation to open the case. I will just assume the unit is "bricked".
I will follow your advice and try to obtain a replacement under the lifetime warranty.
Brian
DaneA
Apr 23, 2018NETGEAR Employee Retired
Hi burchbri,
Welcome to the community! :)
Based from the troubleshooting steps you have done, since the GS108Ev3 switch/es were unable to be reset back to factory default settings, it is possible that there is a fault on the switch itself. I suggest you to open a chat or online support ticket with NETGEAR Support at anytime and let them know about your concern. If ever the GS108Ev3 switch/es were declared faulty, be ready to submit a .pdf or .doc copy of the Proof of Purchase or Sales Invoice of the GS108Ev3 switch/es for warranty verification. If ever the hardware warranty is still valid, an online replacement will follow.
DaneA
NETGEAR Community Team
burchbri
Apr 27, 2018Aspirant
Thanks very much for your reassuring reply, DaneA. I will follow your advice and report the defective hardware early next week.
I have worked on quite a few of this kind of "lightweight" embedded system over the years. With those other devices I have been able to open the outer case and find a serial port 3-pin connector. By hanging a serial-USB dongle off the pins and connecting a terminal emulator, I can usually catch the bootloader and break into a busybox session. That allows me to edit the bootloader environment file and restore a "bricked" device to factory defaults. I have not opened the case of my GS108Ev3 to preserve its lifetime warranty. However, if I were to look at the motherboard, would I find a serial interface and be able to catch the bootloader messages?
