ThomasAV
Sep 29, 2015Aspirant
GS108Ev3 Firmware Upgrade Issues
This is still a problem. I bought the GS108E (v3) last week. I couldn't configure the switch using 192.168.0.239 (my PC has a static IP of 192.168.0.200). I tried updating the firmware from 2.00.03 t...
- Sep 30, 2015
Hello ThomasAV,
Welcome to the community!
I understand you are having some issues updating the firmware of your GS108E. Here are some things that you can try:
1. Make sure you are using the latest version of the utility, you can download it here.
2. Reset the switch to "Factory Defaults", push the factory defaults button on the right side of the switch (labelled) for 10 seconds and let it reboot.
Hope it helps! I'll look forward to your update.
Thanks,
JohnRo
Sep 30, 2015NETGEAR Employee Retired
Hi ThomasAV,
I'm glad it is working after the factory defaults. It is on factory default out of the box, but somehow the first attempt of the update might have corrupted the OS. Please remember to always back up configuration (if ever you configure the switch by adding VLANs and such).
Thanks,
lexav
Oct 29, 2015Tutor
That may have happened to me (Click GSS108E) and to other ones (GS108Ev3), and the OS was so corrupt that the factory default switch didn't help. See that other thread if your factory defaults button does not appear to work:
