vasileiosg
Jan 29, 2017Aspirant
GS108Ev3 VLAN not working
Hello,
So I got that GS108Ev3 and i updated to it's latest version. I might be doing something wrong but my VLAN is not working. Here is what i did:
I connected two physical devices A and B on port 1 and 2 on the switch.
A got 192.168.0.1 (static)
B got 192.168.0.2 (static)
I start pinging them and it is working fine.
then i went to the switch and did the following:
VLAN > 802.1Q > Advanced > Port PVID
And i changed ports 1 and 2 to PVID 2.
Then i went to VLAN > 802.1Q > Advanced > VLAN Membership and removed any VLAN on those ports except tagging VLAN2.
I then tried to ping the two devices and i could not.
Is there something i may be doing wrong?
Thanks!
Hi vasileiosg,
Looking to your comment seems that the error could be related as you are tagging the ports with VLAN 2.
If they are access ports as you described you should Untag them instead of tagging them.
Hope that it helps.
Xavier Lleixa
NETGEAR CBU PLM
- DaneANETGEAR Employee Retired
- XavierLLNETGEAR Employee Retired
Hi vasileiosg,
Hope that it helps.
Xavier Lleixa
NETGEAR CBU PLM
