mrswitch
Jun 15, 2021Aspirant
GS108PE Poe Power Cycling
I understand the Prosafe Plus switches do not have POE power control ability on each port so that you can cycle a single port. However I am wondering if the switch cycles all the POE ports power on r...
JohnC_V
Jun 17, 2021NETGEAR Employee Retired
Welcome to our community! :)
That is correct. Once you reboot the switch, all POE ports will power up too. This will automatically power up any POE device connected to the switch.
John
NETGEAR Community Team
mrswitch
Jun 17, 2021Aspirant
When I reboot the GS108PE will it depower all POE ports and then repower them when it comes up, giving a power cycle to all ports?
- schumakuJun 17, 2021Guru - Experienced User
mrswitch wrote:When I reboot the GS108PE will it depower all POE ports and then repower them when it comes up, giving a power cycle to all ports?
Yes. In fact this is the standard on most PoE switches.
Few/recent sophisticated Netgear PoE switch models introduced an "Uninterrupted PoE" feature which can be enabled if required: Keep PoE running even when rebooting the switch Software reset or reboot after firmware upgrade will not force PoE PD devices to power recycle. Factory default will still reset the PoE controller and pause PoE output while rebooting.
