RevMRHamilton's avatar
Jan 10, 2021
GS108PEv3 Cannot Factory Reset
Hello, Several  weeks ago,   I noticed, via my network monitoring software, that the web interface on one of my GS108PEv3 switches had dropped offline. However, the switch appeared to functioning no...
  • schumaku's avatar
    Jan 11, 2021
    RevMRHamilton wrote:
    1. Any ideas on the reset switch not appearing to  function?    Is there another way to  trigger the reset?
    Netgear ProSAFE plus Configuration Utility - permitting the microcontroller is still partially alive, and the NDSP protocol access wasn't disabled.
    2. Will this work as a "dumb" switch?   I don't consider a "yes" answer as a solution, but only as an indication of whether I can use it in this capacity.  I bought  these  particular switches for VLAN  and POE functionality.  I have them tied to a Cisco 4948, and I want the VLANs.
    Crystal ball is on a holiday - depends what might be broken on the switch in question..
    3. Will the POE  work  without being able to "manage" the switch?
    As abve #2 - plug a cable and PoE PD might help giving an answer. Unclear if the config is retained, or it's back on a default, and VLANs are lost.
    4. Why bother? These switches come with a limited lifetime warranty. Contact Us | Support | NETGEAR -> Replace my defective product
ProSupport for Business
