Rod1253
Dec 09, 2017Aspirant
GS108PEv3 POE Not functioning
OK, I bought this switch with POE to supply power to my Google Wifi Home Mesh network. One of these node plug into the switch and is called Node1. I need to have it in a location with no AC so I want...
- Dec 10, 2017
Hi Rod1253
Welcome to our community!
I look at the Google Home WiFi units and seems that they are not PD devices, so they can not be powered by a normal PoE switch even that they have an ethernet port. In this case I would recommend that you explore to add an AP like our WAC510 instead of the google wifi that are PoE powered or you can try to find a PoE Splitter solution that supports PoE in their input and have a USB-C output to be able to power the google wifi.
Regards
Hope it helps!
Xavier Lleixa
NETGEAR CBU PLM
XavierLL
Dec 10, 2017NETGEAR Employee Retired
Hi Rod1253
Regards
Hope it helps!
Xavier Lleixa
NETGEAR CBU PLM
Rod1253
Dec 10, 2017Aspirant
Thank you so much for your response. I had just got off the phone with Google who stated that these are NOT POE. I honestly didn't think about that at all. Thank you again for your support and recommendations.
