biba
Oct 16, 2018Aspirant
GS108PEv3 setup problems
Hi there,
I am having problems setting up a GS108PEv3 and a JGS516PE network switch. The 8 port switch is for staff accomodation, the 16 port one for the main building.
I am looking to connect fi...
- Oct 16, 2018
Excellent points Nodism1125!
In case neither the Netgear Switch Discovery Tool nor the ProSAFE Plus Utility (which requires the installation of a packet capturing driver) aren't able to discover the switches even if connected direct (computer - switch - router) there might be some Internet "security" thinge blocking the required network traffic in the computer.
schumaku
Oct 16, 2018Guru - Experienced User
Does a similar set-up work when plugged together with just some patch cords near to the router on a desk?
Switches powered by the power supply, the per device Power, PoE Power Status LED are on?
Each switch port has two Speed/Link/Activity LED. The Ethernet links are coming up at all?
Any PoE devices connected and powered by these switches?
- bibaOct 16, 2018Aspirant
Hi schumaku,
To answer your questions:
- Similar, simpler set-ups e.g. router to switch and laptop to switch or router to switch and laptop to router are yielding the same results
- The PoE Power Status LEDs are on for both switches.
- The 16 port switch only shows a steady orange led at the port that is connected to the router. The 8 port switch Ethernet link LEDs are neither steady nor blinking.
- No PoE devices are connected to either switch (no wireless APs).
Don't know if that is of any importance but a powerline adapter (Devolo) is connected to the router via Cat6e cable.
Benjamin
- Nodism1125Oct 16, 2018NETGEAR Expert
Hi biba,
Once you connect the switch to router, the switch will act as additional local ports of your network.
JGS516PE Main Building location
GS108PEv3 Staff location
Which switch is connected to the router?
Are you able get internet access and IP addres wired to the switch? If yes, the switch is working as pass-through switch.If your laptop wired to any of the switch port, ProSAFE plus utility should detect the IP assign by the router unless there's an application blocking it such as antivirus or firewall.
There's another way, the switch has a web GUI to manage the ProSAFE switch. You can also install the NETGEAR Switch Discovery Tool to access admin page.
https://www.netgear.com/support/product/JGS516PE.aspx#download
Correct setup should be:
Internet Modem - Router -> Switch -> Computers
If you have an existing network, connect the additional switch to any working local ports.
- schumakuOct 16, 2018Guru - Experienced User
