biba
Oct 16, 2018Aspirant
GS108PEv3 setup problems
Hi there,
I am having problems setting up a GS108PEv3 and a JGS516PE network switch. The 8 port switch is for staff accomodation, the 16 port one for the main building.
I am looking to connect fi...
- Oct 16, 2018
Excellent points Nodism1125!
In case neither the Netgear Switch Discovery Tool nor the ProSAFE Plus Utility (which requires the installation of a packet capturing driver) aren't able to discover the switches even if connected direct (computer - switch - router) there might be some Internet "security" thinge blocking the required network traffic in the computer.
Nodism1125
Oct 16, 2018NETGEAR Expert
Hi biba,
Once you connect the switch to router, the switch will act as additional local ports of your network.
JGS516PE Main Building location
GS108PEv3 Staff location
Which switch is connected to the router?
Are you able get internet access and IP addres wired to the switch? If yes, the switch is working as pass-through switch.
If your laptop wired to any of the switch port, ProSAFE plus utility should detect the IP assign by the router unless there's an application blocking it such as antivirus or firewall.
There's another way, the switch has a web GUI to manage the ProSAFE switch. You can also install the NETGEAR Switch Discovery Tool to access admin page.
https://www.netgear.com/support/product/JGS516PE.aspx#download
Correct setup should be:
Internet Modem - Router -> Switch -> Computers
If you have an existing network, connect the additional switch to any working local ports.
schumaku
Oct 16, 2018Guru - Experienced User
- bibaOct 17, 2018Aspirant
Good evening,
Many thanks to both of you! I so far only tried the 8 port switch located in the staff accomodation part of the building complex. I temporarily disabled the Bitdefender security suite but still could not locate the switch. I factory reseted the switch and et voila, next time I refreshed the ProSafe utility it found the 8 port switch and even the 16 port one which is connected to the router in the main building (must be due to the fact that I did not disable to the Wifi connection to the main building).
I can now access the switch settings, I enabled all ports and can now use the Ethernet sockets in the various staff rooms.
I am going to try my luck with the 16 port switch tomorrow (time permitting).
