jridder
Feb 10, 2018Aspirant
GS108PEv3 switches DHCP address
I just purchased the GS108PEv3 about a week ago. Went through setting it up including switching it to DHCP so that it would be easier to discover and access through my LAN. A few times now I have gon...
- Feb 10, 2018
All these switches revert to the default 192.168.0.239 IP address if the switch port to the router (with the DHCP server) is disconnected and reconnected, or the switch is restarted/rebooted - and the DHCP server does not honour the DHCP request.
Aside, DHCP client is default on all these switches, too.
schumaku
Feb 10, 2018Guru - Experienced User
