DJEPSON
Nov 02, 2016Aspirant
GS108T set up
I am having a nightmare setting this up ! I have connected port 1 to a port on my router and as the manual says then connected an ethernet cable from one of the other ports to the laptop, I have ...
- Nov 03, 2016
Hi DJEPSON,
The GS108Tv2 is a smart switch. You need to change its default IP address to an IP address that is within the IP range of your existing network so that you could manage it easily. As you could observe the instructions I have posted, the GS108Tv2 can be managed via a browser which is, for me, is more convenient rather than using the Smart Control Center utility.
It might be that you need someone to assist you in doing the steps above to set it up. With regard to that, you may contact NETGEAR Support at anytime.
However, if you think that what you need is just a plug-and -play switch, then you should opt for an unmanaged switch. Kindly access the link below for a list of NETGEAR Gigabit Unmanaged Switch models that would fit your network needs.
NETGEAR Gigabit Unmanaged Switch Series
DaneA
NETGEAR Community Team
DaneA
Nov 02, 2016NETGEAR Employee Retired
Hi DJEPSON,
Kindly try the steps below:
1. Disconnect the GS108Tv2 from the existing network.
2. Connect a PC to a LAN port of your GS108Tv2.
3. Set a static IP address of 192.168.0.210 to your PC.
4. Open a browser like Google Chrome. Then, at the address bar of it, type 192.168.0.239 then press Enter. Login to the web-GUI of the GS108Tv2. Enter "admin" as the username and "password" as the password without the quotation marks.
Note: The default IP address of GS108Tv2 is 192.168.0.239.
5. On the web-GUI, go to System > Management > IP Configuration. Select "Static IP Address" then assign an IP Address, Subnet Mask and Default Gateway that corresponds to your existing network. Then, click Apply.
Note: You will lose access to the web-GUI of the GS108Tv2 because you have just change its IP Address which is normal.
6. Connect a LAN port of the GS108Tv2 to your router.
7. Set your PC to "Obtain an IP Address Automatically." Then connect it to a LAN port of the GS108Tv2.
8. Open a browser like Google Chrome. Then, at the address bar of it, type the static IP Address you have set to the GS108Tv2 then press Enter. If you are able to access it, then it means that the GS108Tv2 is now a part of your existing network.
Note: You may also perform a connectivity test. Open command prompt on your PC then ping the static IP address you have set to the GS108Tv2 (for example: ping 192.168.1.18 then press Enter). If you receive replies then it means that the GS108Tv2 is reachable within your existing network.
Hope it helps.
DaneA
- DJEPSONNov 03, 2016Aspirant
Thanks DaneA, that sounds like a lot of manually configuration for somethng that is supposed to be straightforward out of the box, I think I will just return the switch for something that is more plug and play
Many thanks
Damian
- DaneANov 03, 2016NETGEAR Employee Retired
Hi DJEPSON,
DaneA
- DaneANov 06, 2016NETGEAR Employee Retired
Hi DJEPSON,
I just want to follow-up. Were you able to seek assistance from NETGEAR Support regarding the initial setup of the GS108Tv2 switch? Also, were you able to check the link I gave you about the NETGEAR Gigabit Unmanaged Switch Series?
DaneA
