tonynsx
Jul 27, 2022Luminary
GS108T to Aruba 2390F 24 port
I have a Netgear GS108T switch that for some reason only works on an Aruba 2390F 48 port switch. If I connect the GS108T to an Aruba 2390F 24 port switch, it won't work for some reason.
I have both Aruba switches setup the same way, VLAN 1 Tagged, and both have the same firmware version. Only difference is one is 48 port, and other one is 24 port.
And on the GS108T, port 8 VLAN 1 Tagged.
I don't have port security on either Aruba switches.
GS108T --> Aruba 2390F 48 port works
GS108T --> Aruba 2390F 24 port doesn't work
Any idea why?
- As we face the same simple GS108T the idea is near that both Aruba switches are not configured the same, or behave different for whatever reason. Probably asking on the wrong community here?
- schumakuGuru - Experienced UserAs we face the same simple GS108T the idea is near that both Aruba switches are not configured the same, or behave different for whatever reason. Probably asking on the wrong community here?
- tonynsxLuminary
Yeah, probably something different on the 24 port Aruba. I didn't setup the switches, so I'm not sure.
Need to look at configs of both.
