jerry2096
Feb 26, 2022Aspirant
GS108Tv2 - does it support trunk port?
As subject - does it support Trunk port? If not, which Netgear model support it? For home lab. thanks
michaelkenward
Feb 27, 2022Guru - Experienced User
You might get more help in the appropriate section for that hardware. Try one of these:
Switches - NETGEAR Communities
Smart / Plus / Click Switches - NETGEAR Communities
Discuss Ethernet Switches Plus and Pro Managed
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in the model number and check the documentation for the hardware.
schumaku
Feb 28, 2022Guru - Experienced User
The crux is that Netgear does not use the trunk port and access port terms, neither in the docs nor on the Web UI on the Plus and Smart Managed series.
