gnah
Jan 01, 2022Aspirant
GS108Tv2 - no firmware tab in management website
I have a GS108Tv2 and i'd like to upgrade the firmware. I only have linux machines, so the Smart Control Center does not work. I thought i could upgrade the firmware instead with http, so i browsed t...
- Jan 01, 2022
Early Smart Managed Pro switches from launched more than a decade ago were initially fully depending on the utility (Smart Control Center), even older ones since the early 2000ands used an even older utility (Smartwizard Utility). Some switch models got a limited Web UI over time as part of the ongoing development, some later ones got even a full Web administration complementing the utility.
The only option is to run a WIndows VM or loan a Windows PC to run the utility required.
schumaku
Jan 01, 2022Guru - Experienced User
gnah
Jan 02, 2022Aspirant
thanks for that information! then i'll try to organize a windows machine and see if that works with the control center.
