yvrhnl's avatar
yvrhnl
GS108Tv2 firmware update
After firmware update on GS108Tv2 switch, is it nessesary to remove previous version of firmware?
  • Hi yvrhnl,
    Welcome to our community!
    I believe the GS108Tv2 do have a file management system that it can handle 2 firmware versions at the same time. You may see it under Maintenance > File Management > Dual Image > Dual Image Configuration.
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi yvrhnl,
    • yvrhnl's avatar
      yvrhnl
      Thanks for the information.  I see how the setup works. Everything under control.
      Regards.
      • JohnC_V's avatar
        JohnC_V
        yvrhnl,
        I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
