yvrhnl
Oct 16, 2017Aspirant
GS108Tv2 firmware update
After firmware update on GS108Tv2 switch, is it nessesary to remove previous version of firmware?
- Oct 17, 2017
Hi yvrhnl,
Welcome to our community!
I believe the GS108Tv2 do have a file management system that it can handle 2 firmware versions at the same time. You may see it under Maintenance > File Management > Dual Image > Dual Image Configuration.
JohnC_V
Oct 17, 2017NETGEAR Employee Retired
Hi yvrhnl,
yvrhnl
Oct 17, 2017Aspirant
Thanks for the information. I see how the setup works. Everything under control.
Regards.
