Rootax
Mar 30, 2016Luminary
GS108Tv2 : Cos and Diffserv at wirespeed ?
Hi, I'll have soon a GS108Tv2, and I'll do some Cos marking on DHCP packets, like this exemple : http://flyovercountry.org/2014/02/google-fiber-gigabit-speeds-your-router-part-2-qos/ I guess ...
- Apr 13, 2016
Hello Rootax,
Speed changes on the switch will depend on the QOS/COS configuration. The switch should still process the traffic at 1G even with the configuration shown on the example. For the chipset, it is using Broadcom.
Hope it helps!
Thanks,
JohnRo
Apr 13, 2016NETGEAR Employee Retired
Hello Rootax,
Hope it helps!
Thanks,
Rootax
Apr 27, 2016Luminary
Hi
Thx, I own the switch now, and even with Diffserv configuration, it's working great at full speed.
- DaneAApr 27, 2016NETGEAR Employee Retired
Hi Rootax,
I'm glad that you got your own GS108Tv2 switch and its working great. :)
Now that it seems that your concerns has been answered. I encourage you to mark the appropriate reply as the “Accepted Solution” on this forum thread so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Cheers,
DaneA
NETGEAR Community Team
- RootaxApr 27, 2016Luminary
Done :)
