lsng
Aug 01, 2022Aspirant
GS108Tv2 cannot disable port mirroring
I recently enabled port mirroring on this switch (after messing a lot with confusing error messages). Now I'd like to disable again, but I can't. I was able to set "Session Mode" to "Disable" again, ...
- Aug 01, 2022
There is no more disable than disabling the port mirroring session. It's disabled at that point, perfectly fine.
lsng wrote:
but I'm not able to completely remove mirroring config. Trying to do so will result in "Error! Unknown Interface":
No way to "remove" the pre-set mirroring config(s).
schumaku
Aug 01, 2022Guru - Experienced User
lsng
Well then, if you say so đ
Thanks!
