TAC57
Jan 23, 2021Aspirant
GS108Tv2 Can't write time?
I just unboxed a new GS108Tv2 that I've had in the box for quite some time. It seems to work OK, but I can't write the date message is "Error: Failed to set Local date". It won't take a new passwor...
DaneA
Jan 24, 2021NETGEAR Employee Retired
Welcome to the community! :)
Kindly try using other browsers or use Incognito mode in Chrome then login again to the web-GUI of your GS108Tv2. Check if the same problem will occur.
What is the current firmware version of your GS108Tv2?
DaneA
NETGEAR Community Team
- TAC57Jan 31, 2021Aspirant
Tried with Firefox in private mode and Chrome in incognito with no luck. Also can't change p/w or update firmware.
Boot: B5.1.0.2, s/w: 5.4.2.13
- DaneAFeb 02, 2021NETGEAR Employee Retired
I suggest you to perform a factory reset on your GS108Tv2. With default settings, check if you will be able to change the password as well update the firmware to the latest version which is v5.4.2.35. You can download firmware v5.4.2.35 here.
DaneA
