dancrosoft
Oct 20, 2016Aspirant
GS108Tv2 LAG with GS116E
I have an issue and a question. Question: Does anyone have a LAG setup with a GS116E to any other switch? Issue: My GS116E will not let me setup a LAG. The LAG dropdown is empty. Have tri...
- Nov 04, 2016So basically I wasted my money due to horrible documentation . Furthermore the support has been one if the worst I have ever had to engage. (Maybe not as bad as Dell but definitely the worst network equipment vendor experience). I now regretfully hit the accept solution button.
My solution: to never purchase another business class Netgear product.
In closing I shall enjoy taking this switch to the range next week to use it as target practice.
Thanks to all involved for taking weeks to figure out the feature in question was actually not supported at all.
Good day.
dancrosoft
Oct 24, 2016Aspirant
Confirmed. Utility is the latest version. I have tried it on several different machines all with the same result.
Also I have tried multiple versions of the tool with multiple versions of firmware.
I performed a factory reset before trying each version of try on another PC.
Do you have access to one of these switches. Can anyone export a config with a LAG configured and send it. I am interested to see what happens if I import a config with a LAG in place.
JohnRo
Oct 24, 2016NETGEAR Employee Retired
Hi dancrosoft,
My advice is to contact our Support Team so that your issue can be looked at further.
Thanks,
