dancrosoft
Oct 20, 2016Aspirant
GS108Tv2 LAG with GS116E
I have an issue and a question. Question: Does anyone have a LAG setup with a GS116E to any other switch? Issue: My GS116E will not let me setup a LAG. The LAG dropdown is empty. Have tri...
- Nov 04, 2016So basically I wasted my money due to horrible documentation . Furthermore the support has been one if the worst I have ever had to engage. (Maybe not as bad as Dell but definitely the worst network equipment vendor experience). I now regretfully hit the accept solution button.
My solution: to never purchase another business class Netgear product.
In closing I shall enjoy taking this switch to the range next week to use it as target practice.
Thanks to all involved for taking weeks to figure out the feature in question was actually not supported at all.
Good day.
JohnRo
Oct 24, 2016NETGEAR Employee Retired
Hi dancrosoft,
My advice is to contact our Support Team so that your issue can be looked at further.
Thanks,
dancrosoft
Oct 24, 2016Aspirant
I did. They escalated and never called me back.. That was more than a week ago.
- JohnRoOct 25, 2016NETGEAR Employee Retired
Hi dancrosoft,
I found the record, it appears that the case is being handled by level 3. Currently the case is being looked up by the engineering team, please follow up with them after a few days. Can you give me a full screenshot of the LAG membership tab, and I'd like to know what error message you are getting.
Thanks,
- dancrosoftOct 26, 2016Aspirant
Not much to see but this is what happens when I try to tick a port and hit apply. The LAG dropdown is empty as shown in a screenshot from above post.
- JohnRoOct 26, 2016NETGEAR Employee Retired
Hi dancrosoft,
Well, you are right. There's nothing much I can get from the error message. I'm still waiting for the case to be updated, I'll let you know.
Thanks,
