mac_mat
Nov 21, 2020Aspirant
GS108Tv3 - adding a static ARP entry - Error: Failed to Add ARP entry. IP subnet does not exist.
Hi All, recently I bought a GS108Tv3, which I use with default factory settings, just to connect my router/NAS/PCs on a local network. My NAS (with static IP) is set to Wake on Unicast, so whenever a...
DaneA
Dec 07, 2020NETGEAR Employee Retired
As indicated in page 265 of the GS108Tv3 user manual here, it says that in the IP Address field, you must enter the IP address of a device on a subnet attached to one of the switch's existing routing interfaces. Regarding this, is the IP address that you entered is on a subnet attached to one of the switch's existing routing interfaces?
What is the current firmware version of the GS108Tv3?
DaneA
NETGEAR Community Team
- schumakuDec 07, 2020Guru - Experienced User
Valid point DaneA !
DaneA wrote:... it says that in the IP Address field, you must enter the IP address of a device on a subnet attached to one of the switch's existing routing interfaces. ...
In other words: The ARP entry can only be added in combination with L3 inter-VLAN routing enabled. Re-thinking it, this does make some sense. At the same time it's confusing, because the switch core IP stack and the NAS are (in many basic network environments) on the very same VlAN and subnet.
- mac_matDec 17, 2020Aspirant
Hi Everybody,
Thanks for the answers, I'll give it a try a soon.
As I'm a complete newbie to setting up VLANs, I'll probably need some time to 'study'. :-)
regards,
mac_mat
