hundoman
Jan 14, 2021Aspirant
GS108Tv3 / GS110TPv3 / GS110TPP - Can you turn On / Off IEEE 802.3az support?
Hello I am a longtime user and fan of Netgear switches and have bought/specified hundreds of them over the years. I can't find in any Netgear manual if following family of switches GS108Tv3 ...
schumaku
Jan 15, 2021Guru - Experienced User
hundoman wrote:I can't find in any Netgear manual if following family of switches
GS108Tv3
GS110TPv3
GS110TPP
has the ability to turn On or Off the IEEE 802.3az Energy Efficient Ethernet (EEE) support.
Looking at the Netgear provided manual on this family of switches but and I can't see anywhere about turning this EEE support On or Off like I can on the Netgear GS728TPV2 model.
Look again 8-) 8-Port Gigabit (PoE+) Ethernet Smart Managed Pro Switch with (2 SFP Ports and) Cloud Management Models GS108Tv3, GS110TPv3, and GS110TPP User Manual - p.94/95 "Configure the global green Ethernet settings" and further on "8. Select the EEE Mode Disable or Enable radio button."
hundoman wrote:For running Dante traffic I can't have EEE running on the switch.
There is more required than just disabling EEE - this EEE something Audionate should get under control in the Dante environment - it's an industry standard for many good reasons.
Strongly advise looking into the AV over IP switches for Dante and similar applications.
