slu
Jul 30, 2022Tutor
GS108Tv3 Enter Registration Key - Please remove this warning
Hello Netgear, we are business customer since over 14 years and have bought a number of large switches. Now we bought a small GS108Tv3 and see this "Enter Registration Key" on the WebGUI, lucki...
- Mar 19, 2023
ZZero wrote:
What about this scenario: ...
https://kb.netgear.com/000061819/How-do-I-find-my-NETGEAR-registration-key
Note: Registration keys are not required for devices running recent firmware. If you cannot update to the latest firmware and require a registration key, use the instructions below.
To find your registration key in the Insight App:
- Launch the Insight App.
- Select an organization.
- In the device list, tap your switch.
- Tap Diagnostics > Registration Key.
- Your five-digit registration key displays.
To find your registration key on MyNETGEAR:
- Visit my.netgear.com.
- Enter your Email Address and Password.
- Note: If you do not have a MyNETGEAR account, see How do I create a MyNETGEAR account?
- Click NETGEAR Sign In.
- Select Products > My Registered Products.
- Select a switch to view its registration key.
- The product view page displays your five-digit registration key.
slu
Jul 31, 2022Tutor
Well i know that i can register the switch, but why i need this at all?
schumaku
Aug 01, 2022Guru - Experienced User
To get rid of the nag message for example 8-) Earlier answer would have said that you can retain the full set of management features.
Look, even if you do not think about ever using the lifetime warranty in case one of these switches should break - it's a great voluntary service by the manufacturer, so doing the registration can't be asked to much. It does not even require an Internet connection from the switch to the Netgear cloud.
