slu
Jul 30, 2022Tutor
GS108Tv3 Enter Registration Key - Please remove this warning
Hello Netgear, we are business customer since over 14 years and have bought a number of large switches. Now we bought a small GS108Tv3 and see this "Enter Registration Key" on the WebGUI, lucki...
- Mar 19, 2023
ZZero wrote:
What about this scenario: ...
https://kb.netgear.com/000061819/How-do-I-find-my-NETGEAR-registration-key
Note: Registration keys are not required for devices running recent firmware. If you cannot update to the latest firmware and require a registration key, use the instructions below.
To find your registration key in the Insight App:
- Launch the Insight App.
- Select an organization.
- In the device list, tap your switch.
- Tap Diagnostics > Registration Key.
- Your five-digit registration key displays.
To find your registration key on MyNETGEAR:
- Visit my.netgear.com.
- Enter your Email Address and Password.
- Note: If you do not have a MyNETGEAR account, see How do I create a MyNETGEAR account?
- Click NETGEAR Sign In.
- Select Products > My Registered Products.
- Select a switch to view its registration key.
- The product view page displays your five-digit registration key.
ZZero
Mar 18, 2023Aspirant
What about this scenario: The switch stops working and requires resetting to start from scratch. So you do the reset and try using the registration code that you wrote down when it was issued to you by Netgear, and which worked to "unlock" the switch. But now that you've reset the switch the registration code doesn't work and yet while you go around and around with Netgear support they never get to the point where, in spite of you making a clear and direct request for a new code, never seem to figure you might need a new code, so you give up and end up using the GS108TV3 to keep the dust off a rectangular spot on a shelf somewhere. That's been exactly my experience with one and only one of these switches I have purchased (which is actually more than one switch since the original and its replacement both failed within months of being put into service). Not ever requiring a registration code would remove a major roadblock that Netgear placed in the way.
schumaku
Mar 19, 2023Guru - Experienced User
