cat139lyleb
Dec 07, 2022Aspirant
GS108Tv3 Firmware Update Failure from old "7.0.7.1" to new "7.0.9.11" and stuck with old firmware
GS108Tv3 did not take an update, so does anyone has the same problem? I already rebooted and tried the update repeatedly, but it seems it stuck with 7.0.7.1, so please help! Thanks!
schumaku
Dec 07, 2022Guru - Experienced User
The switches have two firmware images on board. Have selected the correct image to become active after the reboot?
- cat139lylebDec 10, 2022AspirantDid that too, same result...
- schumakuDec 10, 2022Guru - Experienced UserWhat is show on
1. Configure dual image settings on (user manual page 447), and
2 The dual image status (user manual page 449)?- cat139lylebDec 14, 2022Aspirant
Where the manual book or something? Also how do I suppose to do with 2 ways firmwares updates, I thought it should be simple to do as same as what routers do...
