JamesMS
Jun 07, 2021Follower
GS108Tv3: Inter-VLAN Routing
I bought the GS108Tv3 on the understanding that Inter VLAN routing would be possible. After updating the firmware I set up the switch according to the online manual. After following several sources o...
schumaku
Jun 09, 2021Guru - Experienced User
Provide more information on the switch configuration, including the VLAN and the VLAN port configuration, detailed IP config for the subnetworks and the routing.
According the GS108Tv3, GS110TPv3 Data Sheet , the switch does support "Layer 3 static routing with 32 routes (IPv4) for inter-VLAN local routing".
As the original customer, you can contact Netgear customer service for assistance with the initial config for three months after buying the unit.
