Gminds
Apr 05, 2016Aspirant
GS108v4 ~ possible to turn off the LEDs?
Hello everyone! I just wanted to know, if it is possible to turn off the LEDs of the switch (GS108v4)? I'm planning to use the switch in my Home Cinema enviroment and it would be annoying to see...
- Apr 05, 2016
Hi Gminds,
As far as I know, all of the NETGEAR switches does not have the option to turn off the LED lights.
DaneA
NETGEAR Community Team
DaneA
Apr 05, 2016NETGEAR Employee Retired
Hi Gminds,
Welcome to the community! :)
I'm afraid to inform that there is no option to turn off the LED lights of the GS108v4. The GS108v4 is just an unmanageable, pass-through switch wherein it purpose is to extend the local network if you need more ethernet ports to connect more networking devices.
What I can suggest is that you may use a dark colored cloth to cover the switch LED lights while you watch videos via Netflix so that you will not be disturb by the flashing of LED lights from the GS108v4. The LED lights are essential in knowing the status of the switch.
DaneA
Gminds
Thank you DaneA for your quick response!
Could you suggest me a proper Netgear switch (8-port) which would be capable of turning of the LEDs? Is for example the GS108Ev3 able to turn the lights off?
- DaneAApr 05, 2016NETGEAR Employee Retired
Hi Gminds,
DaneA
- GmindsApr 05, 2016Aspirant
Alright. Still big thanks for the help on this one. I'll claim this thread/ticket as resolved.
