mbrossart
May 08, 2023Aspirant
GS110EMX Link Aggregation with ASUS XT9
I’m trying to set up link aggregation on my GS110EMX to an ASUS XT9. I follow the instructions for the GS110EMX and the XT9. The process seems to work. The switch reports that the LAG is up. Traf...
schumaku
May 09, 2023Guru - Experienced User
Don't know anything about this Asus TX9.
Assuming Link Aggregation Control Protocol (LACP) LAG is correct for the TX9, here again I have to repeat LACP the LAG config it's not applicable or available on the GS110EMX - only static LAG can be configured.
- schumakuMay 09, 2023Guru - Experienced User
Correction - the GS110EMX does support LACP LAG configuration. The mode can be selected by LAG ID, don't forget to enable the LAG, and ensure the port memberships do not overlap with other LAGs. Sorry, my confusion. I've mixed up the config options with another Plus switch model.
