JMSladen
Jul 01, 2017Aspirant
GS110T/GS110TP Multicast overload bug
Hi, I have the following switches on a network, and they all suffer from this issue:
2x GS110T (v5.4.0.6 - latest?)
2x GS110TP (v5.4.2.30 - latest?)
1x GS110TP (v5.0.5.4)
1x GS110TP (v5.4...
- Sep 21, 2017
Hi DaneA,
Sorry for the delay, I had been trying to make sure that everything was stable with the updated firmwares before updating.
As you say they were able to provide an updated firmware, that appears to be working fine for the GS110TP models.
for the GS110T switches I was given a work around from Engineering, which I will post below for anyone else who has this problem:
"The root cause is, the reserved range multicast packets comes to switch CPU and the IGMP application fowards them to other ports in same VLAN. Since, the packets are coming at high rate, CPU is becoming slow and failing to open GUI connection.
On GS110T, you can try installing an ACL and drop the multicast packets in the range 224.0.0.1 to 224.0.0.255. If you need these packets, then configure ACL with redirect action (redirect the matched packets to desired port)."Cheers
James
JMSladen
Jul 12, 2017Aspirant
Hi DaneA,
I believe I have tested the setup before with only the switches running the latest firmware, and the issue was the same.
I will test it again, but it will be next weekend the next time all the equipment is setup together.
Are there any other combinations that they would like proving, such as only GS110TP's, and leave the GS110T's and GS728TS out of the setup?
Are there any other samples that it would be useful for me to capture using wireshark, such as longer duration, or traces covering more of the switches, or showing attempts to use the GUI while the issue is occouring?
Cheers
James
Cheers
James
- DaneAJul 12, 2017NETGEAR Employee Retired
As for now, there are no other switch combination which the higher tier of NETGEAR Support would like to probe. Feel free to capture packets using Wireshark (such as longer duration, or traces covering more of the switches, or showing attempts to use the GUI while the issue is being observed) when you perform the test again after having the switches updated on the latest firmware version.
DaneA
NETGEAR Community Team
