mvduin
Feb 28, 2023Guide
GS110TP firmware version
I'm setting up a GS110TP that hasn't been used in a while so the first thing I did was to check if it was running the latest firmware, but now I'm quite confused... The support page claims the latest...
mvduin
Mar 15, 2023Guide
mvduin wrote:If it's safe to do so I'd certainly like to try more recent firmware (e.g. 5.4.2.36) to see if it works any better than the 5.0.2.22 it's running right now... I've noticed that VLAN management via SNMP is very buggy in this release.
Just an addendum to note that I did end up installing firmware 5.4.2.36 without any problems, although SNMP doesn't seem to have improved.
(We also bought a new GS108Tv3 switch to evaluate which, on its latest firmware (v7.0.9.11), turned out to have the most horribly broken SNMP implementation of any Netgear switch I've worked with so far... *sigh*)
ReneD
Mar 18, 2023NETGEAR Moderator
Hello mvduin,
And welcome to the NETGEAR Community! 🙂
As for your inquiry, it seems you are using a GS110TPv2 since the firmware list you mentioned is available for the V2. It will be best to create a support ticket to Netgear team so they can fully verify the version of your switch since Netgear community do not allow confidential information like serial number and MAC address of your device for us to check here. We always suggest to use the latest firmware for your device and if there is a certain issue on some features that is not working correctly, the support can assist to open an Engineering ticket to address that particular issue you are having.
Have a nice day,
Rene D
Netgear Team
