njc
Nov 29, 2017Aspirant
GS110TP port mirroring not working
Hi Team, Port mirroring not working not workign on gs110TP switch.As i mentioned in the screen shot , port 6 data wants to be mirrored to port 5. but as soon as i enable it , PC that connect to Po...
- Dec 14, 2017
Thanks Eriz , Hopchecn for your support.
My issue is resolved . issue was because my PC (where i used to capture the packet) dropps the vlan packets and netgear send mirrored packets with vlan tagged.
Now i used another PC where it can accpet vlan packets and able to capture mirrored tx and RX packets.
thanks again for your support
(suggestion : pls send plane packets with vlan tag removed else people may see issue with mirrored ports)
JohnC_V
Dec 01, 2017NETGEAR Employee Retired
Hi njc,
Welcome to our community!
It seems that you were having problem creating a port mirroring in your GS110TP. Here is a documentation for reference. If it still doesn't work then I suggest you to create a chat / case online on NETGEAR support and please let them know the status of your switch.
