njc
Nov 29, 2017Aspirant
GS110TP port mirroring not working
Hi Team, Port mirroring not working not workign on gs110TP switch.As i mentioned in the screen shot , port 6 data wants to be mirrored to port 5. but as soon as i enable it , PC that connect to Po...
- Dec 14, 2017
Thanks Eriz , Hopchecn for your support.
My issue is resolved . issue was because my PC (where i used to capture the packet) dropps the vlan packets and netgear send mirrored packets with vlan tagged.
Now i used another PC where it can accpet vlan packets and able to capture mirrored tx and RX packets.
thanks again for your support
(suggestion : pls send plane packets with vlan tag removed else people may see issue with mirrored ports)
JohnC_V
Dec 05, 2017NETGEAR Employee Retired
njc,
I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance.
- njcDec 12, 2017Aspirant
hi JohnCarloV
i am still having the same issue.
regards
Noyal
- HopchenDec 12, 2017Prodigy
Hi njc
"Port mirroring not working not workign on gs110TP switch.As i mentioned in the screen shot , port 6 data wants to be mirrored to port 5. but as soon as i enable it , PC that connect to Port 5 is no more able to access to switch GUI"
- This is perfectly normal and intended. The port you are mirroring to (also called the probe) is no longer a normal port. You will loose all connection to the network as the port no longer acts as a normal port. That is not a bug. It is a mirroring port, nothing else."when 1) i enabled Tx only and 2)then rebooted the board , then i packet to (outgoing )port 6 is mirrored to port 5 and captured in my PC."
- You should not need to reboot the switch in order for the mirror to start working! However, the mirror does work after the reboot it seems. I will have a quick look in the lab today, with a GS110TP to see the mirror only works after the switch is rebooted.
Cheers- njcDec 12, 2017Aspirant
Hopchen wrote:Hi njc
- This is perfectly normal and intended. The port you are mirroring to (also called the probe) is no longer a normal port. You will loose all connection to the network as the port no longer acts as a normal port. That is not a bug. It is a mirroring port, nothing else.njc >> ok got it thanks
- You should not need to reboot the switch in order for the mirror to start working! However, the mirror does work after the reboot it seems. I will have a quick look in the lab today, with a GS110TP to see the mirror only works after the switch is rebooted.njc >> i checked it again found reboot is not required. with out reboot i am able to mirror the TX packets. this is fine.
but issue still remains , i cannot mirror both TX and RX packets .(only TX can be mirrored )
Cheers
