gwaitsi
Jan 12, 2021Guide
GS110TPP auto-ds continuing shutting down port/s
I have a GS110TPP with a TLink WR1043NDv2 (OpenWRT 19.5) connected as an Access Point. The point the wr1043nd keeps shutting down if i use the auto-ds function. In an attempt to isolate the prob...
schumaku
Jan 13, 2021Guru - Experienced User
Ok, looks like the log is not complete enough - considering the many DoS attributes that can be enabled/disabled in the Web UI. YeZ something the switch engineering must look into.
And then: I'm not sure on how smart it is to shut down a port and expect the admin does manually re-activate...
gwaitsi
Jan 13, 2021Guide
they were all the entries from the specific time the port went down, the other entries, were just standard entries. there were no indications of which rule triggered the port closure (which of course would make a resolution easier). For now i have to disable on both devices so we can continue to work and i will look again on the week. I will setup suricata on the pfsense to try and identify the traffic that is causing the problems.
