Retired_Member
Dec 27, 2020GS110TPv3 time schedule still not working after firmware upgrade 7.0.4.8
After upgrading my GS110TPv3 POE switch to the latest firmware release 7.0.4.8 which should fix the "across midnight time schedule bug" It still doen't work when I want to schedule to power down my POE ports one hour before midnight till 6am the next day. Scheduling within the same day seems to work just fine.
What am I doeing wrong, or is the "fixed" bug still present?
Already tried to drop and re-add the schedule?
- Retired_Member
Yes, have done that many times. I even tried to find a workaround, unfortunately no configuration will make the "day hop" schedule work.
- DaneANETGEAR Employee Retired
Retired_Member,
Let us try to perform a factory reset on the GS110TPv3 then reconfigure the setting from scratch. Observe if the same problem occurs.
If the same problem occurs, kindly open a support ticket with NETGEAR Support here at anytime for further technical assistance.
DaneA
NETGEAR Community Team
