cp_dewitt's avatar
cp_dewitt
GS116E Login Timeout
I've got a GS116E I'm trying to configure but i can't login.  I put it on a network and logged into the gateway, found the switch's IP address, put that in a browser and hit enter.  After some time the browser timed out with no login dialog.  I connected it standalone to a computer with a fixed IP and tried to access it at 192.168. 0.239 and it timed out there too.  I tried hitting the reset button but no change.  It works OK as an unmanaged switch.  I can connect stuff through is and it works but I can't login to configure it.
  • ErwinL's avatar
    ErwinL
    NETGEAR Moderator
    Hello cp_dewitt
    We have not received any update from you. Please let us know if the provided solution helped you with your issue.
    Have a lovely day,
    Erwin
    Netgear Team
  • BrianL's avatar
    BrianL
    NETGEAR Moderator
    Hi cp_dewitt,
    Aside from the above installation guide, you may want to discover the switch and manage it using the NETGEAR Discovery Tool. Also, you can try using another PC to check if you can login to the switch.
    Let us know if this helps.
    Kind regards,
    BrianL
ProSupport for Business
