cp_dewitt's avatar
cp_dewitt
GS116E Users manual
Where can i get a copy of the GS116E users manual?  All I can find is a ProSAFE_Plus_Utility manual.
  • michaelkenward's avatar
    michaelkenward
    Nov 22, 2022
    cp_dewitt wrote:
    That's where I've been.  All it has is ProSAFE_Plus_Utility_UM_EN.pdf  and the install guide.
    https://www.netgear.com/support/product/GS116E.aspx#docs
    Did you download the file?
    You may find that it also applies to your GS116E.
    What are you trying to do that needs the manual?
    You might also do better of you posted your message in the right place. This section is for WiFi Routers. Your device is a switch. Not much similarity between those.
    Switches - NETGEAR Communities
ProSupport for Business
