cp_dewitt
Nov 21, 2022Aspirant
GS116E Users manual
Where can i get a copy of the GS116E users manual? All I can find is a ProSAFE_Plus_Utility manual.
- Nov 22, 2022
cp_dewitt wrote:
That's where I've been. All it has is ProSAFE_Plus_Utility_UM_EN.pdf and the install guide.
https://www.netgear.com/support/product/GS116E.aspx#docs
Did you download the file?
You may find that it also applies to your GS116E.
What are you trying to do that needs the manual?
You might also do better of you posted your message in the right place. This section is for WiFi Routers. Your device is a switch. Not much similarity between those.
Switches - NETGEAR Communities
michaelkenward
Nov 22, 2022Guru - Experienced User
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
cp_dewitt
Nov 22, 2022Aspirant
- michaelkenwardNov 22, 2022Guru - Experienced User
