vim_usr's avatar
vim_usr
GS180PEv3 management VLAN reachable via guest VLAN
I originally posted this on the Ubiquiti forums, but have determined that my Netgear GS108PEv3 appears to be the issue.  Details of my network and problem are below:   I have setup a Ubiquiti Edg...
  • schumaku's avatar
    Jan 05, 2019
    No, this is a limitation of the platforms used for most Smart Managed Plus switches (GSxxxE) - the CPU port can't be restricted to a certain VLAN only. Bet you have no such control for a management VLAN on the UI (only few Smart Managed Plus have, like the XS724EM). And just based on the IP address the switch won't "magically" add a VLAN config or ACL - the management IP is active on all VLANs on these models aimed to be very lightly managed, that's all.
    Wonder why you posed on the other vendor forum - it's clearly a (well known, many times) discussed and explained limitations of these very simple managed switch family.
ProSupport for Business
