John1623
Aug 17, 2025Follower
GS305E mobile WiFi loss of connection.
Newbie alert, hello everyone. I have a simple set up from a router to the GS305E switching device which is hard wired by Ethernet 40metres away. This works perfectly with one computer working ...
schumaku
Aug 17, 2025Guru - Experienced User
John1623 wrote:I can’t find any settings for parental controls or update timings on the insight app.
The GS305E isn't Insight manageable at all - just discoverable.
No parental control on a switch.
What is the make and model of the router?
