jcahow
Apr 27, 2023Initiate
GS305EP not connecting
Picked up a used GS305EP switch off eBay and it does not seem to be working correctly. It does power up (green power LED) and it will power an IP camera on ports 1-4 (green right LED). It doe...
ReneD
Jul 27, 2023NETGEAR Moderator
Hello jcahow,
And welcome to the NETGEAR Community! 🙂
You can try updating your firmware and resetting the device to factory default and see if the switch will function properly. If not, then the switch may potentially be faulty and needs a replacement. However, we only replace products that are purchased from our authorized reseller, and purchased brand new.
https://www.netgear.com/support/product/gs305ep#download
Have a lovely day,
Rene D
Netgear Team
