LoBer
Mar 31, 2020Tutor
GS308E - Random port stops working
Hi. I have recently purchased two GS308E switches and only one of the two is facing the following issue. During normal usage I randomly loose internet connection. It happens several times a day, b...
JohnC_V
Apr 01, 2020NETGEAR Employee Retired
Welcome to our community! :)
It seems that you were having issues with the ports being dropped randomly. How many devices are connected to the switch? Normally, it just shuts down the port whenever a broadcast storm is being detected on the switch. Does it happen on a specific device?
John
NETGEAR Community Team
LoBer
Apr 01, 2020Tutor
Hi,
thanks for your answer.
On port 1 I currently have a long (80m) ethernet cable connected to another GS308E switch: this port has never stopped working.
On port 3 I have a low speed access point servicing wifi connections.
On port 8 I have a direct gigabit connection to my desktop PC.
The problem occurs frequently with the port directly connected to my desktop PC, but also the other port stops working sometimes (less frequently).
The physical port itself does not matter, since the problem occurs event if I plug the cables on different ports of the switch.
Is it possible to block broadcast storms on the switch or on the Windows 10 machine?
Thanks,
LoBer
