LoBer
Mar 31, 2020Tutor
GS308E - Random port stops working
Hi. I have recently purchased two GS308E switches and only one of the two is facing the following issue. During normal usage I randomly loose internet connection. It happens several times a day, b...
JohnC_V
Apr 07, 2020NETGEAR Employee Retired
Broadcast storms are created by traffic that is going on with your network. You can try to connect a device one by one in order to distinguish which one is actually providing that high traffic in your network.
John
NETGEAR Community Team
- schumakuApr 18, 2020Guru - Experienced User
JohnC_V It must not be required to disable to fix this issue. IGMP Multicast Snooping is a feature that should work as designed. If this does shut own ports randomly, something is borked on the switch config resp. the firmware.
- LoBerApr 19, 2020Tutor
Update, the problem has not completely disappeared, the port shutdown still happens but far less frequently.
